Old 03-20-06, 10:22 AM   #61 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Re: Olivers Ride RF with ZF
Ken,
I'm not sure that you had to go all the way to Australia for your manifold. It looks virtually identical to a crossram manifold, built in house, by TWM in California.
Very nice, no matter where it's from!!!!!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Just curious...will you need to trim the fiberglass around the induction hole, or will the manifold squeeze through there?
Fatal Attraction is offline
Old 03-20-06, 12:20 PM   #62 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Rep Power: 0 Johngt40 is on a distinguished road
To flip or not to flip??????
Not flip.. Pantera shift patern...simpler install with out the exspensive modifications to the gearbox.
Johngt40 is offline
Old 03-20-06, 12:41 PM   #63 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Johngt40 is offline
Old 03-20-06, 12:49 PM   #64 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Johngt40 is offline
Old 03-20-06, 12:53 PM   #65 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
BACK DOOR VIEW
Johngt40 is offline
Old 03-20-06, 01:08 PM   #66 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Throwout mockup
Johngt40 is offline
Old 03-20-06, 01:10 PM   #67 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Plant With Frans "RCR" gorgous valve covers
Johngt40 is offline
Old 03-20-06, 01:18 PM   #68 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Larger Master clutch to handle the larger throwout bearing.
Johngt40 is offline
Old 03-20-06, 06:37 PM   #69 (permalink)
Frank Beuker's Avatar
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
Rep Power: 7 Frank Beuker has a spectacular aura about
but you've got a different bellhouse then is fitted to the pantera zf
your's is lower
look's smashing
Frank
Frank Beuker is offline
Old 03-20-06, 06:52 PM   #70 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
The bell housing is from Kenedy engineering. It is a very nice piece for $350.00. ERA is around $1000.00 more or less. It is alot lower than the flipped version. This also allowed the engine to be lower in the chasis. The oil pan had to shave a litle more so it would not hang over the chasis. It is a very nice fit.
Oliver
Johngt40 is offline
Old 03-21-06, 07:03 AM   #71 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 24 Chris Melia is a glorious beacon of light
John
I do like those valve covers.
regards
Chris Melia. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Chris Melia is offline
Old 03-21-06, 12:29 PM   #72 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
i've orderd one from john wisher
that one is also very low
but it has to be flipped
i've started already so just got to finish it
Frank
Old 03-21-06, 06:18 PM   #73 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
[ QUOTE ]
your's is lower
look's smashing
Frank
[/ QUOTE ]
How can it be lower? The input shaft still has to align with the crankshaft. Correct?
[img]/ubbthreads/images/graemlins/confused.gif[/img]
Pantera1889 is offline
Old 03-22-06, 01:45 AM   #74 (permalink)
ckouba's Avatar
ckouba
5 Tenths
GT40: RCR40-31
That's what I thought too. Assuming same clutch size it would just give more or less clearance (internally) around the pressure plate.
Chris
ckouba is offline
Old 03-22-06, 06:32 AM   #75 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
sorry i mend smaller
if i take a look at his bellhouse and compare it with mine
the radius of mine is larger
