| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Build Logs For build threads and build diaries only. |
03-20-06, 10:22 AM
#61 (permalink)
| | Fatal Attraction Bronze Supporter
Join Date: Nov 2001 Location: Lewes, Delaware, USA GT40: Ex-DRB #35
Rep Power: 21  | Re: Olivers Ride RF with ZF Ken,
I'm not sure that you had to go all the way to Australia for your manifold. It looks virtually identical to a crossram manifold, built in house, by TWM in California.
Very nice, no matter where it's from!!!!!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Just curious...will you need to trim the fiberglass around the induction hole, or will the manifold squeeze through there?
Bill |
03-20-06, 12:20 PM
#62 (permalink)
| | Johngt40 CURRENTLY BANNED
Join Date: Jul 2005 Location: 86 Grad IIT Chicago MJR. Mathmatics/Physics GT40: Il.
Rep Power: 0  | Re: Olivers Ride RF with ZF To flip or not to flip??????
Not flip.. Pantera shift patern...simpler install with out the exspensive modifications to the gearbox. |
03-20-06, 12:41 PM
#63 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF .. |
03-20-06, 12:49 PM
#64 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF ... |
03-20-06, 12:53 PM
#65 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF BACK DOOR VIEW |
03-20-06, 01:08 PM
#66 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF Throwout mockup |
03-20-06, 01:10 PM
#67 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF Plant With Frans "RCR" gorgous valve covers |
03-20-06, 01:18 PM
#68 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF Larger Master clutch to handle the larger throwout bearing. |
03-20-06, 06:37 PM
#69 (permalink)
| | Frank Beuker Silver Supporter
Rep Power: 7  | Re: Olivers Ride RF with ZF but you've got a different bellhouse then is fitted to the pantera zf
your's is lower
look's smashing
Frank |
03-20-06, 06:52 PM
#70 (permalink)
Rep Power: 0  | Re: Olivers Ride RF with ZF The bell housing is from Kenedy engineering. It is a very nice piece for $350.00. ERA is around $1000.00 more or less. It is alot lower than the flipped version. This also allowed the engine to be lower in the chasis. The oil pan had to shave a litle more so it would not hang over the chasis. It is a very nice fit.
Oliver |
03-21-06, 07:03 AM
#71 (permalink)
| | 10 tenths
Rep Power: 24  | Re: Olivers Ride RF with ZF John
I do like those valve covers.
regards
Chris Melia. [img]/ubbthreads/images/graemlins/wink.gif[/img] |
03-21-06, 12:29 PM
#72 (permalink)
Rep Power: 7  | Re: Olivers Ride RF with ZF i've orderd one from john wisher
that one is also very low
but it has to be flipped
i've started already so just got to finish it
Frank |
03-21-06, 06:18 PM
#73 (permalink)
| | Pantera1889 10 tenths
Join Date: Jul 2003 Location: Maryland,USA GT40: RCR MK1
Rep Power: 18   | Re: Olivers Ride RF with ZF [ QUOTE ]
your's is lower
look's smashing
Frank
[/ QUOTE ]
How can it be lower? The input shaft still has to align with the crankshaft. Correct?
[img]/ubbthreads/images/graemlins/confused.gif[/img] |
03-22-06, 01:45 AM
#74 (permalink)
| | ckouba 5 Tenths
Join Date: Feb 2004 Location: Phoenix, AZ, USA GT40: RCR40-31
Rep Power: 10  | Re: Olivers Ride RF with ZF That's what I thought too. Assuming same clutch size it would just give more or less clearance (internally) around the pressure plate.
Chris |
03-22-06, 06:32 AM
#75 (permalink)
Rep Power: 7  | Re: Olivers Ride RF with ZF sorry i mend smaller
if i take a look at his bellhouse and compare it with mine
the radius of mine is larger |
