Go Back   GT40s.com > >
Thread Tools Display Modes
Old 6th August 2017, 05:08 PM   #21
graememunro
GT40: SPF Mk1
Re: ROUSH 427IR Oil recommendations.
Thanks for all the advice and video. It is good. I've decided that relatively low stress V8s driven in the summer benefit more from frequent oil changes than an oil that can last a long time. The benefit of good synthetics is that they last a long time before breaking down and can handle higher temps without breaking down. Change frequently and keep oil temp reasonable and synthetics are no advantage. And in value terms a good mineral oil is better value if changed frequently.
Did some research into the Mocal sandwich plate thermostat and found that oil always flows through the cooler even when cold. When hot the thermostat opens and allows a higher flow rate through the cooler.
graememunro is offline   Reply With Quote
Tags
initial, miles, oil, roush, running
Forum Jump
