Old 02-16-07, 07:43 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
HUW PEPLOW's Avatar
HUW PEPLOW
GT40: rf40 118
Rep Power: 4 HUW PEPLOW will become famous soon enough
air filter
I have a roush 342 installed in 118 and with their standard 'oval' filter cannot shut the rear clip as the engine is sitting too high by about 1 inch. Can any one suggest a suitable air filter to fit the holley carb that would give suitable clearance but maintain air flow,
On 'American hot rod andWrecks To Riches have seen air filters that both take air from above and the sides therefore are considerably smaller,Any ideas or anyone out there with a similar problem but solved it
HUW PEPLOW is offline
Old 02-16-07, 07:50 AM   #2 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Rep Power: 19 brettmcc is a name known to all
Re: air filter
Huw,
I remember but can't find searching the forum someone used a K&N filter that dropped down, you could also put a hat on the top to help air flow even more. I think they are the X-Stream Version. Here's an example at SUmmit: K&N X-Stream Air Flow Assemblies: KNN-66-3040 - summitracing.com
Brett
brettmcc is offline
Old 02-16-07, 07:55 AM   #3 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: air filter
Found it now...: air filter
brettmcc is offline
Old 02-16-07, 08:25 AM   #4 (permalink)
HUW PEPLOW's Avatar
HUW PEPLOW
GT40: rf40 118
Re: air filter
Thanks Brett thats the one I was looking for now see if can find available in the uk
Old 02-16-07, 08:58 AM   #5 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: air filter
Huw,
Try Jegs as well: K&N X-Stream Air Flow Filter Assemblies, Tops and Elements - JEGS
With $ exchange rate it may be better/quicker. Also Jegs charge less for an overseas order than Summit. Jegs charge $10.99; Summit $23.95
Roy Smart GTD Chassis with complete Southern GT Rear modification
Chris Melia Body
Mexican block
Audi 01X that just needs the gear change sorting
brettmcc is offline
Old 02-16-07, 09:59 AM   #6 (permalink)
Mark IV's Avatar
Mark IV
Silver Supporter
GT40: Former keeper o
Rep Power: 15 Mark IV has a spectacular aura about
Lightbulb Re: air filter
For the Holley on P1116 we made a rectangular base that approxamated the shape of the Weber tray and a matching lid. We then found a K&N filter about 1.5" tall that was a large circular shape. Some cuts in the edges of the rubber allowed the filter to be re-shaped into a rectangle. Some 90 degree clips on the top and bottom plates help it to hold the shape and VIOLA! A "Weber" look air filter.
Worked quite well and with the rear deck closed everybody thought it had Webers.
Rick
The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get...
Mark IV is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/roaring-forties-gt40s/20825-air-filter.html
Posted By For Type Date
GT40s.com This thread Refback 02-16-07 08:16 AM
