I suppose my questions may be a little mysterious since I didn't give any background.
The intention is to build a reliable high reving engine with some real world considerations. These are,
1) Components must be placed under as little stress as possible hence a preference to short stroke
2) Giving myself the option to perform a re-bore at a later stage if (when?) a re-build is required.
3) Determining which upgraded components are commonly used, and therefore more afordable, then building the engine within the limitations of these components.
Thanks for the information so far, it has been usefull... although I'm scratching my head a little as to why one would build a 306 given that the increase in capacity is less than 1.5%, and in doing so, making the block a throw-away unit if it ever requires a re-bore???
