I recently managed to 'blow up' my MSD unit when the engine continued to run even though the ignition switch had been turned off.(Read previous post on MSD).
Before I install the new unit I would like to know if it is possible to fit a battery master cut out switch in the main feed (large red wire) to the MSD from the battery? I have conflicting information, as some say that no switch or fuse should be installed in this cable.
