help identifing a ZF
hi can someone advise the details of this trans
Typ 5DS-25,Getriebe Nr
004123,Stuckl Nr 1031002001 (the 3 has a scratch through it,looks like a
and what it would be worth in good order
Trevor Booth
Definitely a ZF, late model, probably a pantera box. should have 7 bolts/studs where it mounts to bell housing. Put it into gear and rotate input shaft, note direction of rotation of out put shafts. This will tell you which way is up. RBT transmissions could value it for you, let me know if it is for sale. There should be a plate on the side with the gear ratios, final drive ratio and speedo drive ratio. common pantera final drive was circa 4.33:1 ??
Trevor
Ya Right Is That For Sale?
I'd Like To See What Rbt Value's It At, And Was Also Wondering If It Would Be For Sale?
Peace
Ryan
Enter >>> The )) Apex
