Simon:
The mandrel with the bead needs to go inside the tube, most rollers have a set of wheels that are larger than 2". If you have a bead roller just get someone with a lathe to make a new smaller wheel and you should be ok.
I have a small bead roller that I converted to do tubing, and it will bead stainless, it just takes a bit more time. Aluminum is a snap.
Good luck
Phil
