Robert,
""I remain amazed that a modern "monocoque" does not have the roof and windscreen pillars as coherent structural parts of the chassis.""
actually the original design does incorporate the A pillars and roof into the monocoque, but it does not get much rigidity from them due to the cut of the doors into the roof.
I think the reason that the kits don't use steel A pillars and roof is that constructing them is very labor intensive and difficult due to the compound curves. This is the only place the original chassis coincides with the outer body so the compound curves are necessary. And the fact that it doesn't give much to the rigidity anyway so isn't worth the extra effort, hence the easier material, fiberglass.
the roof is one of the weak points of the original chassis design although it is very adequately compensated by the side (rocker) torsion boxes. Even with a full steel A pillar/roof you don't get much roll protection. This may be why they added roll bars to some racing GT40's.
to illustrate the door problem with the GT40 here's a pic of a saleen race car (thanks Chris Melia) that has a similar door and what they did to compensate(not pratical for the road) Note the tubing from the top of A-pillar too top of B-pillar
and to illustrate my point of previous discussions about tube frames and triangulation (once again thanks to Chris).
This T70(copy?) chassis is what's known as "fully" triangulated
http://www.gt40s.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=000256&p=2
another little note about the original chassis. The original windshields were triple laminate (as opposed to the common double). Made by a company called Triplex(?). They built(build?) windscreens for boeing. I believe the triple laminate windshield was incorporated as part of the chassis structure to increase rigidity.
as I was typing this reply my flywheel/clutch/starter arrived from KEP, yeee haaa! 600 ft/lb torque custom aluminum pressure plate. 1/2 the weight of a stock porsche unit. SWEET. KACHUNK, uh oh, large piece of wallet is now missing.
[ March 26, 2002: Message edited by: Kalun D ]
