G
Guest
Guest
F. Catt,
I have used these distributors on ford FE motors. You did not state the year and model for this dist, however I will give you some information that should help, as long as you hve the correct coil and module.
Dist purple goes to purple on module, orange to orange on module, black to black on module, ignition coil plus to blue on module with one wire to start on key position, red on module to plus on coil, this is the engine run position and should have a resistor 8 volts, minus on coil goes to green on module, white wire on module goes to plus on coil start on key position, red wire on module goes to resistor run position position. Hope this helps, I could send you a diagram if needed.
