UV/Black light is combined with a dye that you inject into the A/C system.
I find it's simpler to use a sniffer around all the fittings, 9 times out of 10 it's a fitting that is leaking, but this method can be hampered by fans blowing air around, easier on a mid engine. If you don't want to purchase one, call around the local auto parts stores and see if they have a loaner or an UV kit, Autozone often do.
Julian
