408 stroker for sale UK
Some of you may remember I put my engine up for sale earlier this year.
I withdrew it from sale when I thought I might use it.
However, I now have a new GT40 project and I am still intending to go with a 302. While this is a fantastic engine, I think it just has much too much power and torque for a renault box, and I am not in the position to upgrade the gearbox/clutch etc on the car.
As stated, this engine would cost big bucks from dave Whitehust today. However I would be prepared to swap the engine for the best 302 engine offered and some cash.
Please feel free to email or call me if you would like to discuss this further.
Dave Whitehurst Racing (DWR) 408cu in 351 windsor stroker engine. Has been in a road car for slightly over 1,000 miles and is consequently in as new condition.
The history of this engine can be verified by Dave Whitehurst himself. The 408 that he produces has been dyno'd at 490 BHP and a similar amount of torque.
I would be happy to partially strip the engine for inspection, or deliver it to your engine builder for stripping/verification.
The engine comes complete with an aluminium flywheel, hi-torque starter motor, and H/D clutch. The engine also has an 850cfm (enlarged to 920cfm) double pumper carb (although I would recommend rebuilding this)
Please contact me for further details. Full spec below. Cost almost £10,000
Simon
07802 463848
01708 224402
[email protected]
351 Windsor block
Block has been destressed, bored, aligned and decked
Crank is Iron, Lightened, Balanced, Heat Treated, Race Prepared
Flywheel is Billet Alloy with steel centre
Clutch is a Centre Force Clutch, Heavy Duty
Pistons are JE performance pistons
Speed Pro Plasma Moly Rings
Con rods are Eagle steel billet H Beam rods
Cam is Fast Road Flat tappet
High flow oil pump
Canton Sump pan
Heads are Dart Windsor steel heads,
Stainless Steel valves 2" intakes
Crane Roller rocker assembly
High Performance Valve Springs
Elderbrook intake manifold
Holly Double Pumper 850 modified
