Mark,
I am in the middle of fabing a shifter for my 930. I had originally envisioned a rod shift setup, but I have come to the realization that cable is really the only way to go. They use them in the Ford GT I believe.
I went to a "Pull A Part" junkyard and got an 89 Tercell for one hour of my time and $20. The 89 Corolla will work as well. I am sure there are other year models that will work. Placing the shifter frontwards or backwards will only depend on where you want the neutral gate to be. Mine is LHD, so the shifter sits in the middle console. The neutral gate arm sits on the driver’s side for me. It really doesn't matter that much. I’ll explain why in a minute. The main problem you will have is this. The shifter is what I call a central pivot action shifter. By that I mean when the shifter goes forward, the gear selector cable goes backward. With the shifter facing forward(neutral gate cable is on the left side), pull it to the left to select 1<sup>st</sup>/2<sup>nd</sup>/reverse and the lever goes forward. Remember I told you that it doesn’t matter which way you turn the shifter. Here is why. If you turn the shifter around and then pull the shifter to the left, the bracket still goes forward.
I think the only reason for turning it around is to get the neutral selector to go down the right side of the car. If you use the Brandwood transmission bracket or similar setup as shown above, then it won't matter which way you place the shifter for the neutral gate. You still have to attack the tail shaft from the left side of the trans(facing the trans from the rear). Irregardless of the direction of the shifter, the cable is in the pull mode and will have to be mounted on top of the selector shaft to go anti clockwise for 1st - 2nd gear. If it is turned around like Dimi's, pulling the shfter to the left will make the shift arm move in the forward direction also. If you decided to attack the selector shaft from the right, it will still be in the pull mode, but will have to be mounted on the bottom of the selector shaft to get the anti clock rotation. The real limiting factor here will be how close your exhaust is to the selector shaft itself. Too close, and you will have to come at it from the bottom. That will be determined by how low your bodywork opening is for the exhaust pipes. I have a license tag mounting there, so it drops mine down about an inch.
Now lets look at the gear selector cable. The logical way to mount the cables is toward the rear of the car. The trans is back there so why not. Regardless of the direction the shifter is mounted, the gear selector cable connection will move opposite to the movement of the shifter. This is also opposite the movement you want for the selector rod. The shifter goes forward, the cable goes backward, and you want the selector rod to go forward. You will need a Z link to change the direction of travel. If you run the neutral selector cable directly back you will need a bell crank to make the 90 degree turn to the tail shaft.
Let’s say you don’t like the Z link idea. Well there is a way to get around it. If you run the gear selector cable to the front of the shifter and loop it around to get to the tail shaft, you now have a direct relationship with the selector rod. If you do the same thing with the Neutral cable, you turn the pull motion to a push motion. If you come down the left side of the motor, the attachment to the tail shaft is on the bottom. The only thing you have to remember is that a cables strongest action is in the pull mode.
Here are some numbers to remember.
- The shifter gear selector motion is 4 inches maximum front to rear.
- The tail shaft movement is 1 ½” first to second gear.
- The neutral gate of the shifter is ¾” forward and ¾” backward
- For the neutral selector to get the full ¾” movement, the attachment is 1 1/2" above or below the tail shaft. The bell crank has to be a good distance away from the tail shaft so that the in and out motion doesnot pull it in and out. This will give the shfter in the cabin an arc with its shift pattern.
- The measurements of the bell crank(furnished by others on the forum) are in the pic below.
- You can shorten the throw of the Z link gearshift by decreasing the distance of the cable to the Z link centerline.
- You can shorten the throw of the Toyota gearshift in a direct action mode, by shortening the gearshift shaft.
<!--[if !supportEmptyParas]--> <!--[endif]--><o
></o
There is one more alternative to consider for the gear selection cable. That is to modify the shifter with a rod end mounted to the shifter
above the central pivot. Then the shifter becomes a direct action shifter, and can be mounted directly to the gear selector rod
I hope this hasn't been too confusing. I have worked on this thing for some time now and it gave me a headache just thinking about it.
The thing you really don't want is the neutral selector cable making a loop unsupported near the axels. It needs to be supported.
I haven't finalized my own plan yet. What I have found is that it is hard to find cables (1) with bulkhead fittings on both ends, and (2) with 1/4 x 28 ends. TCIauto.com makes them(and sells them) and Summit sells TCI cables. I have found that in using the direct cables in my car requires a 7 ft. cable. For some reason, TCI
TCI - SHIFTERS : Shifter Cables and Summit
summitracing.com charge a lot more for the 7 ft. than any other length. Even more than a 10 ft. cable. Summit prices are less than TCI for the TCI cables(probably dealer discount). Summit however, charges almost double for the 7 ft. cable!?
A last note. I am using rear coolers and this limits the way a bell crank can be used. The coolers are next to the tail shaft and I would have to use a vertical arrangement rather than the horizontal because the crank hits the cooler mounts.
To get a better pic and explanation of the Brandwood setup, go to Big Foot(Randy) web page. It is for a G50-03 which is different from a 930, but it will give you some ideas.
