Mike,sorry about the delay getting the info,but the tire you want to look for is a Toyo Proxes S/T, P295/50R15 105 H. There was a Toyo stock number on the tire labeling of 242120. The companion(exact match) for the front is an R 28 but I can't locate these (this style is/was used on performance Miata's in a different size). A 275/60/15 may be available in the Proxes S/T. The fronts you would most likely use would be the Toyo T1R (225/50/15).Similar tread but with an additional water groove on the outside edges. These are street tires and not at the same level of grip as,say,a Hoosier D.O.T. type race tire,but will wear better and might be less prone to picking up pebbles. These tires have a similar utqg rating as the Toyo RA-1 which is available in a 225/50/15 and is a competition DOT tire but don't know if they're comparable.Also I heard some of the performance Nitto's are made by Toyo. A.J.
