Thanks for your reply Alan.
Just for info my car is a RHD GT40. So the brake lines are not in the same position that a LHD GT40. My master cylinder for front brakes is the one at the center (of the 3 master cylinders) meaning that the master cylinder for rear brakes is on the right.
Following what you said about the cable for the remote cross shaft I think I would need to turn the cross shaft in order to install the cable on the right of the pedal box.
I replaced my 3 master cylinders because the clutch and the font brake master cylinders were leaking so I decided to replace all. I bought exactly the same ones I had (same manufacturer - Wilwood / Same diameter).
I agree with you that before replacing the master cylinders all was OK and when reinstalling the cross shaft I didn't have any choices about the position as I have pin locks on both side of the cross shaft.
So I think the only solution is to bleed again the front brakes and check again the distribution of the front and rear brakes.
I'll let you again but many thanks again for all your helps.
OliveR
OliveR
