Don`t know if you already use these tools "Fillet Balls"?? They are so cheap/easy to use and handy for doing fillets using plasticene, and they leave a real good finnish! Maybe you could find a supplier over your way?
Link: Wax Fillet tool set - East Coast Fibreglass Supplies
Thanks for the note. I made my own not so professional versions of the tools you suggest, by welding balls (from ball bearings) to a bar. The smaller one in the pic is made from a stainless steel welding rod with the ends rounded by a power file applied while the rod was rotated in a drill chuck.
Thanks for your interest and encouragement. I have not been able to spend much time on the project in the last few weeks at all, but should be able to get some more fibreglassing done this weekend
Finally finished making up the first real part. The lay-up I used is:
Gel coat (I first stripe coated all the corners/edges, then two more applications).
1 layer 300 gram CSM.
2 layers 600 gram CSM.
This gave me a final thickness of between 3 and 3.5 mm.
I added extra thickness on the edges, and in the forward part of the door and hinge recess.
The final part weighs 5.5 KG.
The pics are as the part came out the mould, with just the edges cleaned up a bit.
My skills with applying the gel coat and laying up are improving, but still some way to go. I have to keep telling myself "Don't Panic" as I try to get it all done neatly before the resin goes off.
I am very impressed that you did this all by yourself and that you are still at it this many years in,
I would probably have given up ! I have lots of half finished projects around here.....
or gotten profesional help, no not the mental kind but someone who works with fiberglass everyday to do the molds.
Thanks for the positve remarks guys, I am starting to be happy with how things are turning out.
Now almost ready to start laying up the "scuttle" section mold. The parting fences are installed (with 3mm hardboard spacers against the door molds to create the panel gaps) and the surface waxed. Just need to plastacine the remaining small edge gaps and finish cutting all the matt pieces and I can then get on with it.
I decided to do this mold in two parts, hence the locating "bumps" at the centre split line. These were made by casting resin around bolts stood upright in the sections of a plastic tray from a box of chocolates, and then finishing them smooth.
[SIZE=+0]Terry - I am really looking forward to getting back to the mechanical bits. Their is a bit of information about my chassis progress so far at the very front of this thread. [/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]As for running gear, I have a zero distance race prepped Rover V8 to eventually go in, with dry sump and downdrafts. The motor in the pic below is an "old smoker" that I will get the car running with initially. Transaxle is Audi 016 AAZ with an adaptor plate and flywheel of my own design. [/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]Once I get the moulds and first body done I will then fit up the body on the proto chassis (some inner panels to sort as well), sort all the mounting brackets etc and make the wishbones. Then I will have to build up the real chassis and car. - Then comes roadworthy, testing and finally installation of the "real" motor.[/SIZE]
[SIZE=+0][/SIZE][SIZE=+0][/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]Z.C - I knew the scope of work involved, but wasn't expecting quite this duration![/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]Cheers[/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]Fred W B[/SIZE]
[SIZE=+0][/SIZE]
[SIZE=+0]
nice to see that even in SA you are using this engine.
Fred can you do me a small favour? can you measure the distance inbetween the exhaust ports on this engine for me?
I have a little hope these will be more of less the same as my LS1, in which case it might be doable to modify a RV8 cross-over set to fit my application. (ls1 with 180 headers...... )
