The gasket is made in such a way that the water has to flow along the cylinder head, then down into the block through holes in the gasket, along the block, and out of the engine.
Jimbo, you have this backwards-------------- The coolant flow is in the front of the BLOCK, up thru the rear of the block / heads, then forward thru the heads to exit via intake & t/stat housing. Hope you have some of the other plumbing circuits that you may be more familiar with sorted out!
