CAV GT 40 For Sale
Status
Not open for further replies.
S
speed620
Guest
FOR SALE, GT-40 MK-1
CAV Serial Number: 0017, ONE OF THE ORIGINAL CAV'S
LICENSED & REGISTERED IN NEW YORK AS A “1966” (NO EMISSION’S TEST)
Car was assembled & maintained by Bill Andrews, HRE Motorcars Inc.
Outfitted with all requisite safety upgrades
Monocoque chassis, welded stainless steel / roll over and side impact protection
EXTERIOR
Guardsman’s Blue, Painted Le-Mans style (Wimbledon White) stripes
Ford GT sill panel stripes, Static-Cling (removable) meatballs and decals
Length 164.5", Width 70", Height 40.5”, Wheelbase 95", Dry Weight 2,150 lbs.
COCKPIT
Original Blue Ford GT Steering Wheel with custom made billet hub
Fire extinguisher (chrome in cockpit)
Full fire suppression with suppression nozzles throughout
Smiths Instruments gauges (220 MPH)
Hidden air conditioning
Stainless Steel (custom made) screening for: front intakes, grill & rear engine intakes
Adjustable Seats, Pedal Box
DRIVE TRAIN
Ernie Elliott built 347 Stroker (rated @ 480+ HP, 7,500+ RPM’s)
Ceramic coated “Bundle of Snakes” exhaust
Hybrid Getrag (preferred gear ratios) option from Bill Andrews at HRE
WHEELS / TIRES / BRAKES
BRM wheels with Vintage Goodyear 15” rubber
Polished, Color Anodized Knock-Offs (Red, Port Side / Blue, Starboard Side), Safety Wired
Dual circuit, front rear spilt with assistance, tandem master cylinder
11.375" ventilated discs (front), 11.375" ventilated discs (rear)
OTHER DETAILS
Doors & Chassis have Dynamat soundproofing; doors shut solid.
Rack and Pinion, 2.9 turns from lock to lock overall ratio 14:1
(2) 10 gallon fuel safety cells (Sill Mounted) Original style fuel filler caps
Individual electric pumps and filters with dash change over switch
High efficiency, six core front mounted aluminum radiator with twin auxiliary electric fans thermostatically controlled with manual override.
This car was built and maintained with performance and no-compromise quality!
Less than 4,000 miles $87,500.00
For Info & More Pictures:
Call: 516-280-5720 or email [email protected]
A little confusion... the pics DO look monococque but the original CAV's were "semi-monococque" being built around tube framing only. A car advertised on the RM auction site for sale at Meadowbrook this past August, claimed to be
monococque too, but it was one of the original CAV's built just when the South African guys were closing shop but using the last of the chassis provided by GT Developments, technically a GTD-CAV hybrid. Can you elaborate, or even provide build number on the plate? Since the "New CAV" is promoted as being a "real" monococque and "nothing like the original", I just wonder if we can get clarification as the cars come up for sale. Very much appreciated, thank you.
Simon
Simon,
The ad I saw said it is serial number 17 out of the 100 CAV built (Not Auto Futura CAV).
Not sure when CAV started to build mono chassis, but they did build them.
S
speed620
Guest
The actual plate number is: 1A17MONOB66... Does this help?
S
speed620
Guest
The plate in the car indixcates the following:
Model Type: CAV0032 007
Vin: 1A17MONOB66...
S
speed620
Guest
The plate in the car indicates the following:
Vin: 1A17MONOB66...
Status
