The wiring diagrams at the end of the owner's manual don't include turn signals/flasher relay etc. Does anyone have a diagram of this for a CAV? And where is the flasher relay located (presumably under the dash somewhere)? Thanks.
Pull up the nose of your car, you'll find an ali cover near the base of the front screen. Take out the 8 or 9 screws from this cover, flip it over and you'll find all the fuse/relay info your looking for.
Thanks Tom. Removed cover and the diagram was glued to the back. The suspect flasher unit, the only round relay in the bank, clearly visible. Will go from there.
