Good question Keith. The way the hinge points are mounted is different on the MKI and MKII, with the MKI points being mounted on the rear subframe that also carries the undertray. On the MKII the hinge points are mounted either side of a small subframe, that also has the quick-lift jack points on it, bolted aft of the transaxle (see picture). Mine will have have the MKI rear subframe, but also the MKII subframe with jacking points (yeah, I know - unnecessary weight....). So, in theory the MKI and MKII clips will be interchangeable.
