So now you are saying you doubt that anyone was misslead by the missleading fox graph!
You mean no one outside of you and Pete?
Jim, if I took a blank piece of paper and arranged percentages at random heights, could you understand it?
9.1%....
...............9.2%...............................................................8.7%
......................10.3% .........8.6%......... 8.7%......... 8.3%
...............................9.0% ...........8.5%
What represents the most recent percentage?
9.1%....
Domtoni, I really though you were smarter and more obsevant than that!
Its the last space on the chart, from October to November, the unemployment rate declined to the lowest rate of the year, when a number declines, a chart line should show a decline. In this case it should be below the lowest previous point on the chart in March.
Dom,
The Fox chart does not go down!!!!
Domtoni, if they had just used numbers, there would be no problem, but they chose to show a chart.
A chart is used as it gives an easy visual referance, making it so at a glace, you can tell the trends.
Fox used a chart that missreprisents the trend, thats a lie.
Domtoni, if you glanced at the Fox chart, would you know that the unemployment rate had dropped to the lowest point of the year?
When you look at the BLS chart (in white), there is a steep downward slant.
Fox chose to ignore the downward slant as they do not want you to think that things are getting better under Obama!
Domtoni, Tom, did they teach you about chart reading when you were in school?
They say that folks who watch Fox are not too smart or observant, it appears that they are right.
Charts are normally read from left to right, so 8.7 is the simple answer. Quite a quandary, act stupid or admit you're wrong. I see you picked stupid, thank you.Gee Tom,
There is not enough information to answer your "simple" question.
It appears that you have posted random numbers in a random order, with random spacing. Certinally a glance at your numbers reveal nothing.
Why don't you explain it to us.
Domtoni,
One more time, pay attention, it's not that hard, it all has to do with the October to November line.
This is the Fox chart THEIR OCT TO NOV LINE IS LEVEL, IT DOES NOT GO DOWN! Even though the rate declined from 9.0% to 8.6% (lowest of the year) between Oct & November!
This is a correct chart, do you see that the line between Oct and Nov goes steeply down?
The unemployment rate went from 9.0% in Oct to 8.6% in Nov, Domtoni, that is down!
The Fox chart does not go down, the correct chart goes down steeply
Domtoni, if you took a quick look at the Fox chart would you think that unemployment was at the lowest point of the Year?.............. No you would not.
Thats the Fox lie, they do not want you to think things are getting better, do they?
Am I the only one who is suprised at these folks inability to understand this very simple situation?
You would pick the lowest number! Where did you go to school?
Jim, you are really not this dense, on your Fox chart, the number to the right, the latest number is the lowest number. It could have been a higher number but it's not, it's the last number and is 8.6.What do you mean, pick the lowest number?
I received an AA degree from Canada College (71) and a Bachelors degree from California State University, Sacramento (74).....................How about you?
