I am curious, are some superformance gt40 louder than others ? The reason I ask, is that the one I drove with a small block 427 was just plain unbearable. Are all these Superformance gt40 like this or do they very? I have a Pantera can they be quited down or is this as good as it gets?
You have the best air outlet of the SPF GT40s, the Mark II has the single outlet which directs all the air outside, or lets say much better than the MK I. The MK I has about 33% of the air from the radiator heat soaking the front of the tub and creates pressure coming out of the wheel well area with the duel nostril outlets. I took a IR gun and took readings of every part of the inside of the cab looking for heat, the foot well area and the rear bulkhead was the hottest part of the car, both heat soaked from either radiator or engine, 105 F on the front of the tub and 117 F on the access cover of the front of the engine. As you all know an AC unit can only do so much but by reducing all the heat soak I have made it much better than when first purchase. Adding insulation and sound deadening all helps but redirecting the air from the radiator really did the trick. The MK II outlet is great, if you seal up the area where the single nostril exits around the radiator I think this would be all you can do beside insulate the foot well area. I know these are race cars but I am in my mid 50s and need as much comfort as I can get while I can still get around. The first of these pictures are from my templeting the area where I wanted the air to exit, notice the foam around the fans that seal against the new outlets I fabbed. I used poster board to form the pattern then fiberglass mesh and fiberglassed everything. I am not a body man so anyone know better way please chime in.Jack,
Can you please elaborate on the front nostril mod? Although I have a MKII, I'm hoping what you've come up with might work for me.
Rich.
Jim,
Good call on the "closing toll windows with A/C on"; it does improve A/C performance.
I have done what Rick suggests above (cutting out the brake tube openings) and have no noticable heat soak in the footwell.
Also have upolstered removable closed cell foam bolsters behind each seat that prop the back forward 2" and act as thermal insulation (see pic in SPF forum under 2125 upgrades). With individual bolsters if a tall passenger rides the passenger bolster can be removed for seating comfort.
Steve P2125 (MKII)
I always though that the main differance between the GT40 and the Pantara is that I never pretend I'm driving a Pantara. (sorry said:It's Pantera not Pantara. (sorry I could not help myself).
