Covering the rear bulkhead
As I move down the road towards completing my car next month, I am wondering what the best way is to cover the rear bulkhead. Should it be covered with carpet? Leather? Or something else?
I would appreciate any pictures to help with my decision.
Bill D
Bill D
I'm planning on Carpet... Removeable with "Snaps"..
velcro actually works very nicely in this application. I would advise significant sound deadening. I am in the process of taking the entire interior out and adding dynamat and 12 inch neoprene. i expect the driving experience to be greatly enhanced and worth the weight gain.
The industrial velcroe is fine but I tried it in one area on my Cobra and found that heat would cause the adhesive to turn soft and start to release.. After a couple of heat cycles, it was just gummy and would not hold any tension anymore.. It made a big mess.. Now that was on the center tunnel of the Cobra and I did not have any insulation on the other side - it may be an entirely different story if it were insulated..
Bill,
If you want to use self adhered velcro, just put it where you want it and use a couple of pop rivets to attach it.
Randy is correct, heat negatively affects the glue.
Cheers,
Scott
Here you go Bill:
attachment.php
Thanks Bill. That's what I want. Is that your car?
Should I avoid painting the bulkhead to ensure the adhesive keeps the insulation in place?
