40bud said:Is that a completed frame or a work in progress?
Gregg said:Just curious, how much clearance is there between the front suspension and the fiberglass nose?
Hi Dalton,Dalton said:Guys, as Russ says, no doubt you've done your homework. However, the pivot axis of the top suspension arm appears to be about parallel to the pivot axis of the bottom arm on the chassis. Typically the top axis is quite inclined, for anti-dive geometry, such that the rotational moment when the brakes are applied tends to push the nose upwards, balancing the inertial forces pushing it down. Just my 0.02.
Dalton.
How's the project going Don? Any new Pics to share?
