I have a problem that I am hoping someone can help with. I am trying to measure the pulses of a magnet such as those in the 930 transmission. I am told that it can be measured with a multimeter such as the ones from Harbor Freight etc. I can not figure this one out. Have tried most of the combinations without any success. I will try to measure the sensor that Stewart Warner uses for thier speedometer. Mine is at the front wheel and measures the bolt heads from the disc brake. This is a 2 wire setup. If there is a waay for this signal to be shared, then I can use it for a source
What I am really looking for is the number of pulses that the transaxel has per revolution, or for the front wheel. This number will be used in the programing of the electronics in my power steering. But I can't get anything to come up. The only sensors that I can find that will count the pulses is a "go-no go" which I assume is what the speedometer people use to get a signal. The wire from my transaxel is a single wire. I don't know if I have to supply a voltage source to the trans and read the sensor or what. Any help would be appreciated.
