Jack Houpe
I just took the gasket off each of the caps.
With EFI fuel is continually being circulated which heats up the fuel and also creates vapor and fumes, I think our cars originally designed for carburetors are dealing with a number of modern problems which they were not intended for. The solution is a vacuum line to a charcoal canister going to tanks which would be sealed. I discovered that I can not run my EFI system with a sealed tank as it build pressure in one tank not permitting the fuel to cross over from one to another so I have put up with the smell of fuel in my garage when it gets warm. I really don't want to add all the extra lines and tanks as its pretty tight as you all know.
