Malcolm , BF T/A Goodrich I might consider putting them on my trailer,or cut it in half and make a swing out of it, I gather you have learn t a few things along the way.
My comment all related to my experience on my 40 on rear camber gain and or static is you dont need a lot.
I would have to check but I think it only gets about .5 deg per deg of roll.
I found having to much neg give to much rear grip and induces under steer.
I see people often complaining of under steer with these cars, after doing a lot of jerking around it was because of the rear grip over powering the front grip.
As you have no weight on the front tires (no eng) it is easy to end up with to much grip from the rear (it has an engine).
When coming onto the power it will start to sit back and reduce front tire load even more
I reduced toe in to 1mm per side, .5 deg neg static and raised the rear roll center to knock off the tyre loading even more.
The balance went from very disappointing to sensational.
Every car can be different but that is my experience.
Jim
