Is it better to have the Input shaft above or below the pinion output shaft on a transaxle?
Guess it will depend on
- Sump depth,
- Transaxle height
- Height of output shafts
- Plunge depth on CV’s
- Ground effects, venturi and diffuser considerations
I’m thinking that from a handling point of view the input shaft should be above the output shaft, as this would give the lowest centre of gravity.
Is there anything else that needs to be considered assuming that it is possible to flip the ring in a box.
- Sump depth,
- Transaxle height
