Thought I’d post a couple more images of the project. The interior is coming along nicely now. The centre console, ‘flat’ water pipes and two level floor concept works well. Mounting points for the 6 point racing harnesses have been selected and running the throttle cable is the last item to be sorted before stripping everything off, a quick period of miscellaneous welding and then blast and paint the chassis for (hopefully) final assembly. Still a lot of small things to do, though.
This is the first time that the dash, steering column and wheel has been in the car at the same time. I’m pleased with the way it’s coming together. It doesn’t look much yet, but should look good when finished. My interior theme is for black leather and carpet contrasted with alloy trims. The console switches are in and the gearshift gate is being fabricated now. The gearshift collar in the photos is still to be cut down to the correct height. You can’t see it in these shots, but the alloy adaptor between the steering wheel and column has come up well.
The roller throttle pedal mock-up is in place. The throttle pedal will be reversed so that the lever is on the right and the roller on the left. The roller will be made to the correct length for heel/toeing. The block below the pedals is to support my heels correctly and will be replaced with something a bit more elegant. Getting room for my size 13s has been quite a problem.
I’ll be getting the seats, dash, etc upholstered and sorting out some other machining, etc, while the chassis is being painted.
