Lightweight Battery Tray
Status
Not open for further replies.
*NEW* Quick Release Tool Less Battery Tray
This battery tray is made from laser cut lightweight aluminium 16 swg (1.6mm) sheet, it is then precision folded and tig welded before finally being finished in a crinkle black powdercoat. A strap is provided with the tray to secure the battery in place and offers a tool less, quick release, of the battery.
The tray has two sets of mounting holes in the base, so no drilling is required. Simply position the tray and use the existing holes as a drilling guide to secure the box in place.
The tray has been designed to take up as little space as possible and so the mounting holes are positioned within the confines of the tray itself which also adds to the neatness of the design. To prevent the battery from resting on the heads of the bolts the hole positions have been moved to the outer most corners of the tray which allows the weight of the battery to be distributed evenly over the bottom of the tray.
The provided strap can be easily cut with scissors to the correct length once your battery height has been established, once cut I would recommend that you use a lighter to melt over the end of the strap to prevent fraying.
Battery Dimensions:
Depth: 180mm (7.1/8")
Width: 200mm (7.7/8")
Height: Any Size (50 - 250mm+)
This has been designed around the 063 battery which is a very common small battery. The cable supplied will be black, the yellow has been used to easily show how the tray easily secures the battery in place. The yellow strap is also easily susceptible to mucky hands!
If you have any questions please do not hesitate to contact me.
Price: £29.99 + £2.99 Postage within UK.
Its one of the most common batteries stocked at auto parts shops within the UK, on average the output of these batteries are around 45a/hr
These are now available in 3 different sizes for batteries measuring:
177 x 212
177 x 248
177 x 270mm
Status
