Terry Oxandale
Skinny Man
I'm ready to put a viable block into my project, and will be using a dry-sump oiling system. The question I have is in regards the OEM oil pump. My assumption is that this pump must be removed, and the exit port from the pump, into the block, must be plugged. Is this correct thinking, and if so, is there anything in this step that would prevent oilling of the timing chain? Lastly, there is what is often referred to as a "dog-bone" at the back of the block that appears to be inserted into the oil gallery. Is this something that must remain in place, or removed? The dry-sump pressurized oil will enter the block in the same area as the OEM oil filter (at a threaded port into the gallery just behind and below the oil filter).
