Lucas Wiper Motor
I have my Lucas wiper motor installed, the gearbox installed, but need a wiper arm. Suggestions?
Bill D
I found an arm at NAPA, they have a few different types in different lengths..I think the two part numbers I looked at were 60-725 or 60-750. The main issue I had was matching the Lucas spline on the motor.
Phil
Lynn Larsen
Lynn Larsen
Bill,
What is your Lucas wiper motor, or more importantly, the transmission from?
If they are from British cars with the small knurled head, then I don't have an answer for you. If you got it from a Saab, then a standard replacement arm will work. I got mine from NAPA also but it was a Trico generic replacement arm. (I welded a spray bar on it, so I wanted something inexpensive in case I hosed it up.)
BTW, I used never-seize on my cable.
Lynn
