Hi all,
I have now got my pile of parts together as follows:
Rover v8 engine
Rover flywheel
Rover clutch cover & 10.5" driven plate
Various rover gearboxes to supply ali bolt pattern and 1st motion shaft.
Audi transaxle
Audi clutch cover & 240mm driven plate
The rover clutch is larger but looks like it will fit in the transaxle, the flywheel will however not so what I am proposing is:
Chop front off RV8 bellhousing to accomadate Flywheel and machine flat.
1/4 steel plate bolted across this and drilled to suit Audi bolt pattern
Recover splined centre from Audi clutch, machine RV8 1st motion shaft and make a first motion shaft extension to use RV8 clutch.
Extend standard audi clutch actuator to suit.
Can anyone see any issues with extending the 1st motion shaft by 2", I will sleeve so its and interference fit on the existing item and stays true.
Cheers Mark
Seeing the above has got me thinking again now, great looking stuff by the way.
On Zf auto boxes on RV8's you get a spacer, torque plate with ring gear (seperate plates oddly enough) so I could maybe machine down the Audi flywheel and attach in place of the torque convertor, knock up an adapator ring and should be nearly there.
The challenge is as I see it get the face of the flywheel 3cm inside the standard Audi bell housing, small clutch though !
or
Extend the first motion shaft 7 cm out and make an adaptor that will accomadate the Rv8 flywheel and cover (had another look, cover will not fit in that little hole either).
or
Get angry with the transmission and cut the front off (make a note not to destroy the Transmission or will have to repeat things) and get welding on my Rv8 housing.
The attraction of the RV8 clutch is size + lots of suppliers so cheap as chips. Can you get a 10.5" plate with Audi centre , maybe chop out the centre of the audi driven plate and weld into the Rv8 driven plate, voila !
Will a 240mm clutch take 250 - 300 BHP ? YES, IF HAVE PROBLEMS SEND THE ORIGINAL DISK TO A CLUTCH MANUFACTURER AND CHANGE THE ORGANIC FACING WITH ONE CALLES "RASBESTOS". IT IS USED BY ALL THE GUYS CONVERTING CARS IN BULLET PROUFE. THIS MATERIAL IS BLACK AND IT HAS A FRICTION COEFFICIENT HIGHER ABOUT 20% BY BEING A BIT LESS CONFORTABLE IN THE DRIVE AWAY.
This will be my deciding factor because modded standard audi flywheel on Rv8 auto box front end is looking very good now, I do like cheap standard parts as no harsh action or judder.
Regards Mark
Hi Chaps, Many many thanks for the useful advise, and very useful pictures above, I,m going the Kiwi Ka/Fred W B way but without the expense.
240mm clutch on Audi flywheel, maybe get a turbo clutch as rated at 220bhp but I,m tight so will see if what I have survives !
The flywheel is rear weighted so I will have to machine off the back and rebalance; this then goes on to a spacer that will bolt to the ring gear flex plate.
Chop Rv8 bell housing and weld a plate on then drill and cut to fit Audi transaxle.
Job done…. Okay now to put it into practice. So you will have to wait a few weeks for pictures, 18 months for it to run in anger !
Regards Mark
Just a suggestion,
I guess that the clutch release bearing is concentric.
In this case his axial positioning shall take care of the clutch wear which is normally the same stroke that you use for the complete clutch opening.
Meaning:
Check the total stroke of the clutch release bearing.
Bolt the clutch on the flywheel as it shall be and go under a press.
Push on the fingers in order to open the clutch until the disk is free for his natural independence while shifting and add 1mm.
Example of positioning calculation:
Total clutch relaease bearing stroke: Ex =16 mm
Stroke requested for clutch opening: Ex = 8 mm + 1
Stroke for wear adjustment left is 7 mm.
This is the way to find the exact position of the adaptor lenght.
Ciao
Wanni[/quote
Will attach a sample of clutch packaging installation
REMEMBER, USE IGUS PLASTIC BUSHINGHi Wanni,
Thanks for the advise, what I,m hoping to achieve is the flywheel to be in the same relative position as it was on the Audi. GOOD FOR THE RELEASE BEARING POSITION
Before I removed the bits and bobs I measures the distance from the clutch face of the flywheel to the block, this was 30mm. YOU KNOW
My challenge will be to maintain this and the integrity of the spacer, the adaptor ring is around 25mm wide, so I just need to set the Audi flywheel 55mm out from the RV8 block. IS THE STARTER MOTOR ON THE GEARBOX SIDE?
Unfortunately I will not have the flywheel until Monday, however I know that I will not be short on distance so will have to machine either the spacer of flywheel down. This a good oppurtunity to do both and have a recess in one for positive location."""" Unfortunately my lathe only has a 6" throw so will have to farm this work out.... However I then need to find someone with a gap lathe who is both sensible and takes cash !""""DO NOT UNDERSTAND THIS SENTENCE
Another piece of good news is that the hole for the centre pin on the torque convertor is much larger than the first motion shaft tip so I can easily turn up a phospher bronze bush to locate this.IF YOU ARE TO FAR FROM THE INPUT SHAFT, ADD TO THE FLYWHEEL SPACER A BEARING SUPPORT WHICH MATCHES THE SHAFT. DO NOT USE A BRONZE BUSH, PLS.
THERE ARE FANTASTIC PLASTIC MATERIAL WITH A VERY LOW FRICTION COEFFICIENT. CHECK THE IGUS PLASTIC BUSHING. THEY ARE CHEAP AND MUCH MORE DEDICATED TO THE USE YOU WANT TO DO WITH.
CIAO
WANNI
At present I am still on track to do this for pennies using scrap yard parts, which is of course what we all like.
Regards Mark
Is this a material that you machine a part from, or are they supplied as a manufactured part?IGUS PLASTIC BUSHING
Question for Wanni
Fred W B
