Terry Oxandale
Skinny Man
I found I could not run an oil pan (even the shortest wet sump available) in my configuration (inverted 930), which resulted in a dry-dump requirement. This was partially because I was insistent in keeping the vertical angles down to a minumum considering the horizontal angles exist due to the engine being moved forward. I was curious as to what your oil pan relationship was with the ground or framing height.
