Hmmm! the Saga continues....
Managed to get the distributor back in about 30 degrees out (I assume that is a case of rotating the distributor body by the same amount when static timing the engine?).
With the disty back in, I was happy to do a compression test....
Oh my God!!
erm - what should it be?
I am used to seeing figures in the 120-130PSI range on my other cars - but 65!!!!!!
figures are as pic below - these look horrendously low to me, even assuming stock 8.8:1 CR I would expect to see about 115-125PSI.
I am not sure of the ratio between CR and PSI, but am I right that each CR equates to 1 Bar - ie 8.8CR=8.8Bar=130PSI (1Bar=14.7PSI) using air as the medium?
and
the million dollar Q - what would cause them to drop whilst laid up?
The fact that I am getting some figures, makes me believe that there aren't any valves stuck open, at least. It is possible of an HGF between cylinders 2&3, as the figures are identical. I might try and repeat these tests tomorrow.
Pictures of engine strip-down are springing to mind
