Ok, its probably a no brainer but just wondered what you guys thought. I'm "building" (read sending off shell to have someone do most of it...) a euro touring car inspired Mk3 Cortina, for fast road and track use. If I was building a drag car (which I'm not) I'd go for iron block, as for equal money I could get much more power than with an alloy block.
As the car is going to be built with handling in mind, I'm contemplating taking a hit on the power and going for an alloy block.
Power will be at the lower end of things ~350 - 400 HP I guess, compared to getting towards 500 if I went for iron block. It seems to me that saving 100lbs/50kgs at the front end (about 5% of weight of car) is worth more than the power, even if the block is set back as far as possible.
Oh just realised I should have said I'm going for a 302 based engine.
Does anyone else make blocks apart from World / Dart and if so how do they compare? I'll be importing engine to UK, so I'm assuming its more cost effective to import a complete engine rather than the block and get it built over here?
Any advice appreciated. Cheers, Jono.
