Brett James-McCall
Right chaps, you may have seen from my build thread I have a problem getting my olights to work correctly. Need help!
The Setup
Two Lucas Switches as per SGT
31788
4 - Feed (Brown)
7 - Side/Tail (Red)
8 - Jumper to next switch (Blue, but now Black, as I messed up..)
31780
1 - Jumper
6 - Dip Relay (Black/Purple)
8 - Main Relay (Blue Yellow)
The Problem
Apart from 'It No Work', here we go
Flick Sidelights on, they come on. All good
Go down one position and then it jumps to the next switch. At this point yes, 12V comes on and confirmed 12V at the Relay as well - but nothing. The same is for the mains.
The relays have power, they are the top two below
Now, when I short out the Relay Feeds to the chassis they switch. So it's an earth problem, right?
Have a look at the picture, there is no earth on the relays, the power loops; also, there is no earth wire in the loom for the lighting. So how is it supposed to work?
To confirm, the starter relay does trip when you turn the ignition key, so there is no problem there (but it also has an earth in the relay!)
This is doing my head in, please someone help me!!
The Setup
31788
4 - Feed (Brown)
7 - Side/Tail (Red)
31780
1 - Jumper
The Problem
