In an attempt to try and get the chassis finished, I wanted to re-design the rear clam mounting system. The Tornado design has a hinge bar that runs across the back of the car, which is visible below the rear clam. I wanted to a get rid of this feature and have a closer replication of the original design.
From some sketches I’d been given (thanks Brett), they were converted into CAD models and parts were then laser & water cut. The steel chassis brackets are cut from 4mm steel, whilst the body brackets and quick lift hooks are 12mm aluminum
The quick lift jack points have been designed so that they can be bolted in at a later date. A rear under-tray/valance will eventually hide the chassis currently left visible.
Regards
Andy
Regards
Andy
