Hi,
I have a Tilton 800 series Low Profile 38mm 2.14" Hydraulic Release Bearing that I bought for use with my 930 Transaxle. Unfortunately although it fits nicely on the box itself, because I have a custom bellhousing and I'm using a full size Ford clutch, I don't have enough space for it so I've gone back to a mechanical arm. I have no idea if it will fit in a cut down Porsche box with a Kennedy adaptor plate. That you would need to check as that's not my set up. All details on the bearing can be found on the Tilton website. Tilton Engineering - Driveline, , 800-Series
It's a universal bearing, so will no doubt fit other applications.
If you're interested, I'd like £200 + P&P. They go for £325 New.
P&P can be arranged to suite your requirements and will be charged at cost. I'm in the U.K but can post anywhere.
This item is brand new, never used, only taken out of the box and offered up to my gearbox.
Martin
Martin
