My SPF GT40 mk 1 is similar to what you are considering, and I have a couple of suggestions/opinions which are based on my experience gained in ~5,000 miles of street use.
I ordered/built my car with RHD, a 438" Windsor making 630hp, an RBT GT40 specific ZF trans w right hand rod shift, and wide bodywork covering 14" wide rear rubber.
The RBT has worked flawlessly, however I don't track the car. For street use, the RBT is fantastic, and using the RH rod shift is one of the great pleasures of driving the car. Highly recommended.
If you are planning 600+ HP, use a dual disc clutch, and definitely go for the wide rear tires. You need them. And a good limited slip diff.
Just my opinions, good luck with your project.
Jack
Looks just like what I'm after. You are correct - I want to build mine. Can you give me some specifics on your engine, clutch, flywheel, bell housing, transmission, driveshafts, etc. Nyla say go for the 14" wheels. All I can find are 12". Can you point me in another direction. What brand and size of tires?
