Rear Clip Support
Phil G
Anyone know if these rear supports are available for purchase? Looks like they might need to be fabricated.
Ian Clark
No but with a dimension drawing on a napkin and the photo you could get a couple made at a local fab shop:) These are fitted to an RCR GT40, maybe look there first.
Phil G
Ian..It sure is a very nice RCR.
I had no luck finding anything similar so I am having them fabricated as you suggested.
Scott, Looks like Ellis has not been around for a while.
Phil
Phil G
Good question Frank. These cars are fairly new to me and I do not care much about originality I actually like the look of them. What alternatives are you referring to? I am open to all ideas and appreciate any input.
Phil
Phil G
These are perfect! I will order them as soon as I can figure out how to pay for them on there website.
Thanks JP
Phil G
Another great option. I like the Quick Latch though because they will work great with the brackets I am having made.
Phil, Aerocatch is very well made, strong and easy to use, the exposed fixings can be painted body colour and virtually disappears, Quick latch is a bit trickier, it can shake loose and is sometimes is difficult to open. I have fitted springs under the rear lip over the quick latch pins, it helps it to remain a bit more tight and less liable to shake open, and also helps the deck to pop open when pressing the release button. Frank ( Did you get / read the magazine article sent to you ? )
Phil
Hi Phil,
do you finaly fabricate the part youself ?
do you fabricate only one set for your car or some additional set to sell them in case ?
do you use aerocatch on your car ?
(i'm thinking about replace the "homemade work" done on my car to do the same modification like you...)
Regards
Laurent
Phil G
Laurent
I had one set made by a local guy who went off the picture in the first post above. I used the Quicklatch for the Nostril and Rear Clip. You can find some photos in my build log.
Brian Kissel
Here is Phil’s build thread.
Regards Brian
