Now that the engine is back in with the modified water pump, I am able to measure the distance between the RCR-supplied straight solid coolant line running down the side of the car, and the water pump. On the driver's side, the distance is a little over 48". I was originally thinking I would run a single flexible coolant line, but I can't find any longer than 4 feet.
What are you guys doing in this area? Is there a source for longer flexible lines?Two flexible lines with a solid straight in between? Bite the bullet and find someone who will build up a custom set of solid pipes? Any other options?
I'm starting to feel like the coolant lines between the engine and radiator are a bit Mickey-Mouse, with multiple rubber connectors, solid lines and flexible lines. . .
