Spark Plugs
Lynn Larsen
Lynn Larsen
SPARK PLUGS: Use 14mm x 3/4" reach gasketed spark plugs. Heat range will vary by application and may range from Champion N-9Y to N-14Y (or equivalent).Use anti-seize compound on the plug threads to prevent galling in the cylinder head, and torque to manufacturers specification for aluminum heads.
Bye the way, this is quoted from Edelbrock's Performer Installation Guide which I am attaching.
  • 26382-PerformerInstGuide.zip
Tim Kay
Thought I'd bring this thread back for any updates /ubbthreads/images/graemlins/wink.gif
[ QUOTE ]
SPARK plugs: Use 14mm x 3/4" reach gasketed spark plugs. Heat range will vary by application and may range from Champion N-9Y to N-14Y (or equivalent).
[/ QUOTE ]
What range recommendation for 302, mild cam?
With a propensity to foul, would you hotter or colder?
