I am having trouble with my starter on a G50.
The starter drive gear(pinion) engages the ring gear perfectly, about 50% of the time.
The other 50%, it seems to spin before engaging the ring gear, grinding, but not engaging the ring gear at all. The gears mesh perfectly, when they mesh(no binding)
After removing the gearbox for inspection,
the physical evidence bears this out.
I thought perhaps I might have a bad ground,
and ran a ground wire directly from the starter to the chassis, but no joy there.
The voltage seems to be fine.
The starter was very slow the first time I tried to start my engine, I pulled my spark
plugs to see if it would spin faster and it
did not. I waited two hours and tried again
and voila, it spun just fine. I put the plugs back in, and the engine started just
fine. However, since then, this non-meshing problem has become worse.
As I don't want to replace a ring gear, I
am seeking higher knowledge. HELP!
Is this just a faulty starter, or is some-
thing out of alignment?
