'Ello all
As shipped my RCR40 comes with 550lb springs front and rear with dual adjustable QA1 dampers and a front sway bar dia of 1" and rear of 3/4". I have followed Deans set up for ride hight, camber and caster at the front and plan to do so at the rear. Sway bar lever arm length and distance from suspension pivot to link attachment is the same both front and rear. (A one inch bar is about 2.6 times stiffer than a 3/4" bar given equal lengths)
As I understand it increasing roll resistance at the front using a sway bar will increase understeer whilst increasing at the rear reduces understeer/promotes oversteer. Does anyone have any practical data on the effect of sway bars on an RCR40 and what has worked for them? Clearly my aim is to be as neutral as possible for a mix of track and road use. As a start point I am ignoring the effect of changing damper compression and rebound settings in the equation, I can only think through one variable at a time!
Best
John
Best
John
