Throttle cable GTD 1991
Paul Williams
Hi guys can someone please advise me what is the procedure to remove the throttle cable from my car do I need to remove side panel as I can't see even with the car on a ramp how to access this
Cheers Paul
Markus
SPRF40
Not a direct answer to your question but those threads might give you some support....
While changing to the new cable verfiy that the routing is sufficient.
Regards
Markus
Malcolm
If changing the throttle cable, use the old cable to pull the new cable through the side panel else you will definitely have to remove the side panel! Hope that made sense!
These my help if you need to replace the hole cable which I recommend, you need to go to this point to get to it . This is a GTD RHD !
