I've been trying to find it somewhere in the tech section but was not succesful.
I've modified transmissions in the past with an external cooler and pump, activated by a temerature switch circuit, so it would circulate and cool in situations required.
I've also built a transmission once using an engine remote filter mount with thermostat and it would circulate via a pump and depending on temerature via the cooler.
My knowlegde of the UN1 is limited and I wonder if someone has done this before, my gut would say to use the oem drain as a pickup and spray on the crownwheel/pinion, or make multiple spraypoints...
I hope if someone has info, input or preferably any pictures or drawings, can they please put them up?
Thanks in advance,
best regards,
Randall
Thanks in advance,
best regards,
Randall
