Hi Howard,
Great question. The quick answer is yes, you can remove the numbers from the roundel without damage. The trick is to use the correct type of film that is specific to short term use (2-3 years) OR use static cling numbers. Either way, you can remove the numbers at will.
As for the roundel/stripes combo, I can setup the sill stripe with a roundel cut-out. Applying the sill stripe first and the roundel after is the easiest way to do it and would be the way we setup the graphics for you. I have an excellent install guide and application tools are included.
These can also be done in 3M paint mask - all digitally cut like the vinyl. I've sold to Cobra owners and many GT40 owners to date with very positive feedback.
Any questions or requests - just ask.
Hope that helps
Chris
Hope that helps
Chris
