Anyone have rough ideas of the differences with pin drives and bolt ons in the weight department? I'd hate to go to the trouble of worrying about weight in various areas of the car, and then simply miss out on XX lbs of weight reduction on something such as this.
Pin drive wheels are going to have an adapter, spinner, most likely a spacer plate in some cases - all of which a bolt on wheel won't have. And all of it is unsprung weight which is the worst of all possible weight if you are on a weight elimination campaign.
Are the pin drive wheels heavier than lightweight bolt on counter parts? I have never weighed a pin drive wheel by itself. Seems an aluminum spinner and adapter are going to be around 2-4 lbs by themselves for sure. If the wheel is heavier than a bolt on by a similar amount or more, then there might be a lot of weight savings here.
R
R
