what you talking about ?
To my knowledge every high strength fiber part ( carbon or glass) is made with epoxy resin. If you are looking for lightweight high strenght parts, the only way to go is using wooven mats, lay it up in the correct direction ( according your main load needs), using the correct epoxy resin ( according your temperature and shere strength needs). If one wants to have the infinite strenght to weigth ratio use prepregs, vacuum and pressure ( autoklav).
If you talk about bonding strenght. polyester is the weakest, than follows vinylester and then epoxy. All the high shere strenght glues are epoxy based.
OF course it takes more time to cure, but it will give the better parts if used correct.
We made a fairing for a BIMOTA SB9 recently. It is a rather complex mould (13 parts) but i allowed us to use epoxy, wooven mats , corefoam and vacuum it. The finaly part weighted only 1050 grams and it is of exceptional strength and stability. THe only drawback is that the bloody painter added almost the same weight in paint.
Pretty clear for home use polyester and vinylester ( you need to accelerate it, otherwise it will be sticky for a long time) is the most easiest and practical to work with. Especiallywith using vinlyester don´t forget the correct work protection.
TOM
